SOURCE: PCL XL ERROR INSUFFICIENT MEMORY
you can try to use the HP 5L driver instead of the canon driver, I suspect you get this error when printing PDF files
SOURCE: navigator will not start
I had the same problem.
Adding twain_32.dll to the Windowsfolder solved the problem.
For people who don't want to search for it: Look Here.
Then you won't get this error but one saying to reinstall the printer driver. Just do it and the problem is solved.
SOURCE: error message - insufficient memory
Lower your resolution. 300 dpi at %100 magnification should be more than enough for printing purposes.
SOURCE: Have a cannon lide 200. Mp Navigator gives
There are a couple of reasons this can happen. 1) Do you have other TWAIN scanner drivers installed, remove the other scanners files from the C:\Windows\TWAIN_32\ (cut and paste the other folders into the C:\Windows\ directory.) Depending on your OS, you may need to click Yes for permission to move the file (Administrator). Start in My Computer (or Computer), double click (or single click) on C: (Local Disk), then scroll down to the Windows folder and double click (or single click) and then repeat for the TWAIN_32 folder and right click on the folder you need to remove (cut). Hit the back arrow and right click to find the Paste command.
2) How much memory do you have on your computer? How many other programs were running at the time? What is the Page File size (for Windows)? Check that you have sufficient memory to run the MP Navigator. Windows tends to be a free memory hog and doesn't release memory cleanly sometimes.
I hope this helps.
