Apple iPad 4th generation Logo
Fran Agnew Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just updated iPad 4 and window pops up asking for VPN authentification even though I have it turned off.
I just updated my iPad 4 and it wants VPN authentification, even though I have it turned off. It won't allow me to use my iPad without the authentification.
lemonwaan
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 69 Answers
  • Posted on Mar 01, 2015
lemonwaan
Expert
Level 2:
New Friend:
Greenhorn:
Answers
69
Questions
Helped
17944
Points
281
Yes, you can use your ipad without that, but you should pay for any internet service
Cannot open ipad asking for a pass code and says ipad has not been updated
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
How do I delete vpn from my apple ipad air 2?
Do what you have done but when you go to VPN Configuration you should see a Blue i in a circle tap in on that icon. You should then see the settings for the VPN, at the bottom you will see Delete VPN click on that.
How can i get my pad to show home page
http://www.dummies.com/how-to/content/how-to-reset-ipad-settings.html How to Reset iPad Settings Life may not have a reset feature, but iPads do. If, for some reason, you want to return your iPad to its default settings, you can reset them. The last item under iPad's General settings is Reset. When you click it, you get options for resetting the following:
  • Reset All Settings: Every one of the preferences and settings are reset, though information you've added to apps like Calendar and Contacts doesn't change at all.
  • Erase All Content and Settings: This one both resets your settings and erases information you've added to apps like Calendar and Contacts. This is useful if you plan to sell your iPad.
  • Reset Network Settings: By choosing this, any networks you've set up are removed. iPad will also turn off Wi-Fi, and then turn it on again, which disconnects you from any network you're connected to. Note that the Ask to Join Networks setting stays on.
  • Reset Keyboard Dictionary: When you turn down iPad suggestions of words as you type, you can add words to the keyboard dictionary. You do this by tapping a suggested word, which rejects it but adds the current spelling of the word to the dictionary. If you don't want to keep all those added words, use this reset option.
  • Reset Home Screen Layout: If you want to get back to the original home screen you saw when you took iPad out of its box, choose this reset option.
  • Reset Location Warnings: When you use an app like Maps that checks your location, it asks you if it's okay to do that. When you tap OK to let it proceed two times, it stops asking. If you want it to start asking again, tap this reset option.
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Why can't I get into updates on my ipad?
you'll need to connect to itunes and restore your ipad as new because it has a software bug.. you must not back up when you restore because the bug will not dissappear, you will lose everything though.
10answers
How to delete VPN from my iPad
To delete vpn from you ipad you can simple go to Settings > General > VPN. Here you will see all the vpn connections created on your device. Here you can delete it. You can review detailed instructions here: Sahrzad VPN How to Setup Guides
1helpful
2answers
I cant get my yahoo mail because my i pad will not connect to my wifi
If your wi fi will not connect then you need to get that sorted before you are able to get your mail. To do this I suggest turning the iPad off and go and unplug your router - the one connected to your computer from the wall for 5-10 minutes. Go back and plug it back in and that will power cycle it. Once you have done this go back to the iPad - Tap Settings > then Network >tap the wifi button and slide to on > then select your network and you will need your password.
Once you have done all of that you should be able to connect.
Let me know how it goes.
For step by step video guides for the iPad covering all features head over to >> http://www.tabletmastered.com/blog/
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
