SOURCE: taken delivery of 40" samsung
Make sure you have it set to wireless off in the menu or it will not recognise the ethernet port on the back even if it is flashing. Most tvs with browsers come with the wirless function set to on. Also if it has search for internet signal you could try this to get it to rec. as well.
SOURCE: No Facebook app on optica smart tv
What is the exact model number to your TV? Look for this detail, at its back cover. Gopakumar Gopalan Google
Testimonial: "Model no 7042. That's all it says. Sku is t844 not sure what that is thought I'd put it on here incase any good. Have you an idea what to do?"
Do a hard reset to this set and check. If it do not help you, contact the authorized service center for RCA. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
