Cuisinart SS-700 - Single Serve Brewing System Logo
F
Fay eng Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
When prompting to brew coffee or hot water , it drips water very slowly
Gary Munson
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 03, 2021
Gary Munson
Contributor
Level 1:
Answers
Questions
0
Helped
1867
Points
9
Marie Kirk
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 40 Answers
  • Posted on Feb 26, 2015
Marie Kirk
Expert
Level 2:
New Friend:
Cheetah:
Answers
40
Questions
0
Helped
12764
Points
107
It might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
  • Denise Duff
    Denise Duff Apr 25, 2016
    Thank you the vinger helped
2answers
My Saeco Odea Go makes coffee very slowly
If the water pressure coming out of the steam/hot water arm is fine, then the issue is likely with the brew unit or the grinder. Here are a few things you can check:
  1. Clean the brew unit: A dirty or clogged brew unit can slow down the flow of water. Remove the brew unit and clean it thoroughly, making sure to remove any coffee residue or buildup.
  2. Check the grinder: A dull or clogged grinder can also slow down the flow of water. Make sure the grinder is set to the appropriate setting for your coffee beans and check that the grinder is not clogged.
  3. Check the water flow meter: The water flow meter measures the amount of water flowing through the machine. If it is clogged or damaged, it can affect the flow of water. Try cleaning the water flow meter with a soft-bristled brush and see if that helps.
  4. Check the water filter: If your machine has a water filter, it may be clogged and affecting the flow of water. Replace the filter if necessary.
If none of these solutions help, it may be a more serious issue and you may need to bring your machine to a professional for repair.
2answers
Why is my delonghi ec702 brewing slowly even after regular descaling? The water barely drips out even with no coffee in the filter.
I had same problem, now gone. Check your water Intake filter in the water reservoir. If it looks discolored, it may be clogged. I used a brush and plain water to clean it off, and now machine works like brand new!
My Seaco Royal Machine has got double problems. The first one is; water dripping from the bottom to the floor. The second is; coffee coming out slowly (drops ). The second is; the sounds that accompany the...
The leak may be due to a clogged weep passage that resides behind the brew group and empties into the drip tray in the front. Take a long piece of wire or a good paperclip and straighten it out. Take some hot soapy water and a small syringe and wash that area out with the drip tray installed. As for the coffee coming out too slowly, you may want to adjust the grinder to a more coarse grind by one or two clicks. After each single adjustment to the grinder, it will take two brew cycles to catch up to the adjustment. Don't make too many adjustments without running at least two cycles in between each adjustment. If that does not solve the problem, you may need to take it to the repair center nearest you to have them check out the pump.
10helpful
2answers
Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Water dripping slowly
You can get urnex at most reputable kitchen shoppes or order it. it will do a great job or you can run vinegar through the machine... be aware that it will smell horrible and will nedd to have at least 2 or 3 cycles of water ran afterwards but brewing this cycle a couple of times will bust up the lime. Doing it every month or so afterwards will keep it from coming up again. That would be my first step... hope that helps!
5helpful
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Can I adjust the water flow for finely ground coffee?
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
4helpful
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Coffee stopped coming out of nozzle
The problem with your machine is the connection where the brew unit connects to the dispensing head is broken. This is why the machine is leaking into the dump box. I wish it was an easy fix, but it is not.
You will have to get the machine serviced.
If you would like to have your espresso machine serviced please visit the service page of our website:
http://cerinicoffee.com/Espresso_machine_service.asp
Cerini Coffee Services
Authorized Saeco Service Center
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
