SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
