Brother PE770 Computerized Sewing Machine Logo
S
Sheila Skidmore Posted on Feb 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
I have adjusted tension, changed needle, rethreaded nothing seems to help.
Chance Miller
Level 2:
Sergeant:
  • Brother Expert 455 Answers
  • Posted on Feb 26, 2015
Chance Miller
Brother Expert
Level 2:
Sergeant:
Answers
455
Questions
Helped
113808
Points
904
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
I have a brother PE770 embroidery machine the bottom thread is loose even after adjusting the tension. so loose it will bunch up and get caught in the bobbin and the piece is ruined.
Try to loosen the bobbin tension a small amount and put your top tension at four. When you get a good stitch then you have the bobbin stitch set right. If you still can't get it set then it is probably the top tension spring that needs to be replaced.
3answers
I have a brother PR1000 and on the test stitch there is too much bobbin thread showing underneath. do I adjust the tension in the top thread or the bobbin tension?
Yes Adjust to more tight see what it'll do.
Bottom bobby is too tight or upper thread control is too lose.
Good luck
Mai
1helpful
3answers
My top thread is thick on the back side of the embroidery item. And top stitches have loops. Help
1. thread machine correctly.
2. make sure the bobbin is installed spinning the right way in the bobbin case.
3. put the tension knob back to middle (if this is possible numbered tension knob)
1helpful
My Brother 2800 keeps making loud clicking noises and the top thread keeps shredding. What can I do? I have changed the needle, completely cleaned the inside, tried new thread and it keeps happening. I...
Hai Kim, Please change the correct size needle. Otherwise corrected the design in computer. For ex: stitches 12,702 decrease the design some 1000 or 2000 stitches.
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Why are no embroidery stitches showing up, the needle moves in and out of the fabric but no stitches stay
here are some suggestions, if the suggestions don't help then the
machine needs to be checked to see if there is a adjustment or
timing problem
1. try changing the needle
2. try rethreading the machine top and bobbin
3. make sure the bobbin is turned the right way in the bobbin
case
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
1helpful
3answers
Tension of pe770
Besides the other advice here, check your bobbin case. At first I didn't get my thread hooked into the bobbin case properly and had problems that looked like the bobbin tension was not adjusted properly. I have to take the case out, put in the bobbin to make sure it's caught properly and then put it back into the machine. This is what worked for me.
2answers
Brother pe770 bobbin thread is showing on top of fabric.
First check threading. If it is done properly, then it's probably because it is dirty between the lower tension blade and the bobbin case body. Remove this blade, clean, reassemble and it shoud work.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
