There are no buttons to press near the display
Look at the dashboard screen. On the bottom right there is a black button poking out oft he plastic screen cover. Press and hold this for a few seconds and the time will start to flash. Then keep pressing the button until the correct hour appears. leave it for a few seconds and minutes will start to flash. keep pressing until it is correct. Leave the button alone and the time will be set.
This is assuming that you want to change the clock on a Scenic II?
Hope this helps
The button on the bottom right hand side of the radio. It's the button that looks like a T.
Testimonial: "Thanks for trying but there is no button of that description"
Ok. Has your car got built in sat nav? If so the time settings are accessible through the sat nav menu
With the ignition on but the radio off. Click the top left button on the remote stalk to activate, +/- to adjust then the left button for changing minutes. Click the left button to set.
still nothing! i will ask at the garage!
OK. If you don't find the answer at the garage, give me the VIN and exact model of your car. (Sorry for my bad english)
If you have a satnav installed - go to change prefences, page 4, set time
Angela, Burbage, Leicestershire
