How do I get game off of TV with the redi remote rc58a
I hit game button by accident on bottom of remote and it is now a blank screen with game showing on the bottom right hand screen. How do I get back to regular TV?
If there are no manual buttons on the edge of the tv you are out of luck. Feel around the Bottom, Right and Left Edges of the screen to see if there are any buttons there. Otherwise you will need find a universal Remote or contact the Manufacture for a replacement.
There is button on your remote labeled TV/AV . Press the button to get a blank screen with AV written on the screen. If your game device is connected at the back to this AV socket ( Yellow / Red / White ) you will see the game menu display. On some of the TV remotes it might not be written TV/AV but INPUT SOURCE or just a picture of a TV screen with an arrow pointing inwards ( that LOGO is the universal symbol for INPUT )
The Redi Remote has 35 buttons under a front sliding cover. The programming functions are under the sliding cover.
If you have any questions regarding Redi Remote operation, please call us at 1-800-REMOTES (736-6837)
Followed the manual to return to the Default settings, using the remote "in the blind" pressing the arrow and Enter buttons, hoping I hit the right menu button. I did. Case solved. Thanks
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
blue clock set screen.
is seen due to no signal
as due to Accidently hit remote might have got defective or setting must have disturbed.
refer owner's manual which you must have received during buying set.
good luck
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
