SOURCE: IBM t30 battery does not charge
The problem could be the internal battery charger board ( a small daughter board that plugs in the the motherboard) has gone bad. You can check out this site to: http://www.ibm.com/support/us/en/. Ray
SOURCE: IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
SOURCE: IBM T22 Battery won't charge & is not detected
Take it to a very good technician who will open it up and check a dry joint in the charging system. Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor. Delicate soldering may solve your problem. Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
SOURCE: IBM T23 Thinkpad battery does not charge
I think you have a battery problem and that is why it is not charging properly. Its need to be recllibrated. Try this
Run your laptop of the battery until the whole battery power comes to zero. When it does the laptop will shut down automatically. Now connect the charger and try to recharge the battery. Don't turn on the laptop, just switch on the charger.
Wait for about two hours, and start your laptop. If you see the same thing as before, then you might need to change the battery.
