Model number L40FHD41
I always use Google to get the instructions for my remotes. It helps to look on the label for the brand and model number of your remote, then just Google away. I have used the method successfully several times. Another fun trick is to check on your phone for remote control apps. I use my phone as backup when my grandkids misplace my remote. :-) Good luck.
The TV does not have persay a code. A universal remote has different codes which should be in the owners manuel for the remote, google the remote control model to see a copy of the remote manuel.
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central
2. Settings
3. Remote Control
4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
SOURCE: Venturer TV
to program the direct tv remote to any non listed device, press and hold the tv button until all lights stay lit, then press the small red tv power button, then press the channel up button repeatedly until the tv turns off, then press the red record button. may have to find the best code that wokrs all functions by repeating the above steps several times-
Paul
