Save config
After changing all the necessary parameters using the CLI, use the write
command to save your system configuration. If you receive any error messages,
your configuration has not been saved. You must correct the errors and re-issue the
write command.
Notification of write errors is presented in a two column display:
? The left column contains the parameter values that you set in this session and
need to be changed.
? The right column contains the parameter values currently saved in the
Cajun P116.
Wait 15 seconds for confirmation of the write process. Then exit Privileged level by
typing exit at the prompt. For example, CajunP116-priv# exit.
The cursor changes to CajunP116> to indicate that you are in Normal level.
Verify that all the parameters were accurately saved by using the show all or
show all list command.
The Cajun P116 is now ready for cabling and operation. You may exit your CLI
session.
