Canon PIXMA MP495 InkJet Printer Logo
A
Anonymous Posted on Feb 24, 2015
My black ink button on my pixma mp495 printer is blinking. Why?
Seerwan
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 12, 2015
Seerwan
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3689
Points
5
Actually if the printer didnot work with the above answer which are written.you should do the following;1-take the catridge out and if it is empty,you can inject 3cc of ink slowly on the sponge of the cateidge, and replace it again then restart the printer.2-if this doesnot work,take the catridge out n replace it several times each time tune the printer on and off.3-the final solution is that,take the whole catridges out n clean the sponges of them which put in the ground of the printer ,then replace then again. Hope these work.
Printer Thinker
Level 2:
New Friend:
  • Canon Expert 24 Answers
  • Posted on Feb 25, 2015
Printer Thinker
Canon Expert
Level 2:
New Friend:
Answers
24
Questions
0
Helped
26128
Points
147
If the printer says the cartridges are empty, and will not let you print, just hold down the stop/reset button on the printer. That should clear the error.
Canon MP230 Override Empty Cartridge Message
Chris Harvey
Level 3:
Master:
  • Master 447 Answers
Chris Harvey
Master
Level 3:
Master:
Answers
447
Questions
0
Helped
141194
Points
1166
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
How do I find ip address for canon pixma mp 495 printer?
To print the LAN settings, press the Maintenance catch on the printer over and over unti you see a n on the LED, then press the Black or Color catch. When it prints out, let us know whether the association is Active or Inactive. On the off chance that it is Active, please let us comprehend what it appears for the IP Address and Default Gateway. If you want to get proper detailed information then 'you should call on 1-888-924-2961 toll free number anytime for canon printer support service. Technical Support For Canon Printer
CAN I PRINT WITHOUT A COLOUR CARTRIDGE ON CANON PIXMA
regarding your question, the printer is designed to work on two cartridges.. if you want to print black and your printer has a depleted colored cartridge, you can reset the level of you ink via long pressing the red button (stop/reset). hope to be of help.
CANON MP495 INK LIGHTS FLASHING
Try to press and hold the resume button (the triangle in a circle button) for about 5 seconds. In this way the ink level monitor is disable. Only if you put a new cartridge the ink level will be enabled.
Regards !
1helpful
Mp495 scan without cartridge
It's a funny thing but, after trying everything above, I just pressed the SCAN button on the printer, instead of trying to do it from a program in the computer. It scanned the document and launched MP Navigator!
Cannon mp495
The printer will detect if there is any cartridges that has run out of ink and will not print until the empty ink cartridges have been replaced.
2answers
2helpful
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
old marine
old marine
ZJ Limited
ZJ Limited
