When I tried to login in it said "this login info is invalid pls try again" and I tried many combinations of my password username and email, but it still won't work.
It doesn't say what to put in the two slots to login and I don't know. Can someone help
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
192.168.1.1 is the router's Ip address which will take to you to its ADMIN console. Defualt username is: admin and password is: password or admin. Try these. Once logged in you can then configure the router as required. Dont forget to set the WEP key to make your wireless network secure. WRT54G2 is the name of your router which is sending you the request to fill in the login details.
It is possible that, since the firmware update, the standard username an password have changed. Try some other standard username/password combinations (see link).
When you're able to login, I would advise you to change username and password. If you leave both at the standard setting, anyone can access your router (and even change username and password). Asus WL 500g Login Instructions
Try looking on the modem itself, sometimes they have their default username and password written on them.
Try combinations of "user" or "admin".
eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
