Televison & Video Logo
A
Anonymous Posted on Feb 24, 2015
Ihhave a 32 inch Luxor smart TV and I need to reset it back to factory settings can anyone help me?
Level 3:
Top Expert:
  • Luxor Master 76,851 Answers
  • Posted on Feb 24, 2015
Luxor Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006772
Points
237762
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
4 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 04, 2010
SOURCE: LCD TV flickers non-stop
More likely to be bad LCD controller, see sample here: notes: I removed the cover from the board. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: there are more than one version of the board, http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
Be careful when remove the back cover! the switch assembly is attached to the back panel, do not yank too kard to remove the back.
Anonymous
  • 1779 Answers
  • Posted on Jan 17, 2010
SOURCE: i connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Anonymous
  • Posted on Mar 15, 2010
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
David Baisa
  • 73 Answers
  • Posted on Mar 24, 2010
SOURCE: I have a Sharp 32 inch LCD TV (LC-C3234U)that sits
Try the head phone jack there are some kool remote systems out that support the head phone output.
you can also place them anywhere in the room.
Testimonial: "very helpful!"
1helpful
Hi I have a harwa 32inch smart TV. It was working yesterday but today when I switch on it only show start up screen and remote doesn't work then?
If your Harwa 32-inch smart TV only shows the startup screen and the remote doesn't work, try these steps:
  1. Check remote batteries.
  2. Power cycle the TV.
  3. Reset the TV to factory settings.
  4. Update TV firmware. If issues persist, consult Harwa support or consider professional assistance.
3answers
Connect Luxor tv to internet
Question moved to Luxor Television category.
Most smart televisions do connect via cable. It is a much faster connection.
Google
Luxor model manual
or
luxor model connect to wifi
will have the details of what it can and can't do.
2answers
I have 55 inch Luxor tv and I need to use headphones as I am hard of hearing. I have had tv now around 3 years. Still no luck. Please help with info.
Question edited for typos.
If they are cordless headphones powered by Bluetooth, you just need to pair them again.
If they are wired you may have worn out the headphone socket. Have the socket replaced, get a Bluetooth Dongle for it and Wireless headphones, so there are no moving parts and no wires.
There is a video in this link that should help you.
https://www.google.com/search?q=55+inch+luxor+smart+tv+access+headphone
This one
https://www.youtube.com/watch?v=8JsVqV9mpsw
Luxor 43 inch hd smart tv has cut out twice whilst watching, managed to turn back on after 5 days, now been out for another 4 days, any help appreciated
The power cable faulty it seems to be a common problem in Luxor TVs if confident unscrew tha back panel the cable is on right hand side of the TV three pinned connection . Release the connector and replace. Or get s TV engineer . He'll repair £10 or £20 . I had same problem six months ago after replacing cable the TV works perfectly
1helpful
How to reset luxor smart tv to factory settings
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
I cannot add channels to my luxor 40 inch tv
Do a reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If reset too do not help you, the main system control memory IC to your set is faulty, and should be replaced.
Contact any service technician.
My luxor flatscreen tv. Dtv option has been removed ive lost dtv anyone know how to get my dtv back on my tv ?????
factory reset in main menu/system.settings, if you are connected to the internet try software firmware upgrade also. ....but factory reset and new set up should do the trick.
Top Luxor Televison & Video Experts
Paul Bade
NOEL
NOEL
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
