Watches Logo
A
Anonymous Posted on Feb 24, 2015
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR WESTMINSTER CHIME QUARTZ WALL CLOCK.
Paul Hansson
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 24, 2015
Paul Hansson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1489
Points
10
Without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Hope this tip helps.
r/David
on Feb 17, 2010 • Watches
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
1helpful
2answers
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 • Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 • Watches
1helpful
4answers
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 • Watches
2helpful
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 • Watches
4helpful
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 • Watches
1helpful
2answers
Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Nov 02, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
