Looking for a walking foot attachment for my straight stitch Riccar RD-101 industrial sewing machine
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
