Hisense LHDN32V66AUS 32 in. LCD TV Logo
A
Anonymous Posted on Feb 24, 2015
Chang the backlight in my Hisense tv? - Hisense LHDN32V66AUS 32 in. LCD TV
Level 3:
Top Expert:
  • Hisense Master 76,851 Answers
  • Posted on Feb 24, 2015
Hisense Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003733
Points
237762
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
I have a 75 in hisense tv and one evening in the middle of a movie the screen went black
If it's Hisense it's most likely backlights that are bad, average life of a Hisense TV is 26 months, needless to say there are betters sets for the money. There are 2 choices with your TV, order backlights from shopjimmy.com and change them yourself for around $100 with shipping or recycle the TV as it will cost around $400 to take it in to a repair shop for service, might as well buy a new TV then. If you decide to repair it yourself you will need suction cups to handle the panel, without you most likely will damage it, another downside to Hisense is the panels are very thin and very fragile
1helpful
3answers
Light blinking on and off button. Hisense 55 inch,,, model no.50r6e3
A blinking red light on the power button of a Hisense 55 inch model 50R6E3 TV could indicate a problem with the TV's power supply. It could be caused by a malfunctioning component, such as a blown fuse or failed capacitor, or it could be an indication that the TV is overheating. In some cases, a blinking red light can also indicate that the TV's firmware is not up to date and needs to be updated
2answers
I have a Hisense television with no backlight, no light in front when checked with flashlight.
Hi Henry, since the tv is not turning on to check for any video in the background then it gets a bit more complicated to pinpoint where the failure might be.
This TV has a power supply and main board combined in one board. Replacing the whole circuit board might fix it but it could also be defective LED's strips.
Let me know if you require further assistance.
1helpful
2answers
My Hisense tv model75h6570g has sound and a black screen there is no trace of a picture with a flashlight and the standby light flashes around 20 times before shutting off
Hisense only has 10 blink codes, on most brands they're helpful but not as much on Hisense, in 9 out of 10 sets it turns out being backlights, we've had sets before in our shop where an image wasn't visible, but it still turned out being bad lamp strips. Power boards are a bit different on Hisense sets as loss of backlights can put the set in sleep mode leaving only the standby voltage. Best way to troubleshoot the set would be with a backlight tester
CAbles for Hisense Roku TV
Walmart and Target and Amazon and Kmart and whichever TV provider that you guys are using would have cables for your TV then.
1helpful
I have a hisense tv Model # LTDN42V77US I have sound but no picture. When I check for backlight, I can see some for only a couple of seconds, then they go out. Is that my problem? (backlight)
It is a common problem for the Hisense TV, the problem is defective back lights ASSY, you need to find the burned, or shorted LED diodes on the defective strips & replaced it (them).
5helpful
2answers
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Top Hisense Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
MrFixitSTTL
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
