Aww, dear old Larry Ng, AKA Gone forever
goneforever. Oct 22, 2022
NO gap means missing spec in manual or eyes looked at valve gaps and see none?
It has HLA (Hydraulic Lifters) or solid tappets.
Get the service manual and see?
And some information from me! Larry was always economical with words, failing eyesight.
predator valve clearance....don't seem right
ATVConnection.com
https://atvconnection.com > ... > Polaris
Dec 27, 2004 - The spread sounds perfectly normal to me, but ALWAYS adjust it according to factory specs. Remember exhaust valves get way hotter than intake, ...
Predator Valve Adjustment? - ATVConnection.com ATV ...
Dec 11, 2002
Predator Valve adjustment!!! - ATV Connection
Aug 8, 2005
1997 Sportman 500 valve lash - ATV Connection
Jun 21, 2005
predator 500 wont start! help! - Page 3 - ATV Connection
Jun 11, 2015
More results from atvconnection.com
What is valve clearance spec on a polaris predator 500?
Answers.com
https://www.answers.com > What_is_valve_clearance_...
Oct 22, 2022 - Intake not more then .0069 (.20 mm) but not less then .0051 (10 mm). Exhaust not more then .0119 (.32 mm) but not less then .0081 ...
Adjusting the Valves on the Predator [Archive]
ATV Riders
https://www.atvriders.com > vbb > archive > index.php
Sep 6, 2006 - you will turn that a hair either clockwise or counterclockwise until you see the "T" lined up in the upper area where the 6mm plug came off.
Help with Predator Valves
Polaris ATV Forum
https://www.polarisatvforums.com > threads > help-wit...
Apr 19, 2019 - Yes, when you can no longer set clearance because no thinner shim is available, you have to install new valves or get the valve seats ...
How to do a valve adjustment!!!!!! - Polaris ATV Forum
Feb 4, 2011
predator no start ' Polaris ATV Forum
May 4, 2011
Cam Replacement/Valve adjustment/ decompression release
Dec 29, 2018
Valves Ticking?? - Polaris ATV Forum
Jan 9, 2012
More results from www.polarisatvforums.com
