Sewing Machines Logo
A
Anonymous Posted on Feb 23, 2015
Is there a special type of monofilament thread to use?
Monofilament thread keeps breaking. Tension has been loosened, and the stitches look really good, but the thread keeps breaking.
R.A. Ellis
Level 3:
  • Elna Master 12,731 Answers
  • Posted on Jul 19, 2015
R.A. Ellis
Elna Master
Level 3:
Answers
12731
Questions
Helped
2618792
Points
59176
There are very fine monofilament threads made for sewing (not the old stuff that was thick like fishing line). One thing you will want to do is use the monofilament in the top thread but a regular thread in the bobbin.
One thing I learned when using monofilament thread for quilting is that it sometimes doesn't work well on the machine's built-in spoolholder. Our instructor had us scotchtape a safety pin or paperclip (just run the tape through the open part so only one side of the pin or paperclip is taped to the machine) on the back of the machine about midway between the spool holder and the first threadguide on the left top. If you have a detachable threadholder, set it on the table behind your machine and let the thread feed from there (you can move it around to make adjustments as well as adjusting your thread tension). The pin/clip becomes the first threadguide for your monofilament thread. Run the monofilment thread from the spool, through the pin/clip, and then through the first threadguide on the left top.
If you don't have a detachable threadholder, you can make one by hammering a long nail through a small piece of board and putting your thread spool over the nail.
Tally Girl
Level 3:
  • Elna Master 1,134 Answers
Tally Girl
Elna Master
Level 3:
Answers
1134
Questions
0
Helped
398622
Points
2496
I would suggest that you don't use this thread, it is too fine for the tension device on a domestic sewing machine, and they just don't like it. Too strong, too fine. Its best used in industrial blind hemming machines, if you look at RTW trouser hems you'll often see monofilament utilised here.
4 Related Answers
Anonymous
  • 255 Answers
  • Posted on Jan 11, 2010
SOURCE: My thread keeps breaking, I have changed thread
I suggest you change your needle and make sure you're using the right needle and thread combination for the fabric you're trying to sew. Also, don't use old thread. Exposure to sunlight and age weakens thread. If the tension on the top thread is way too tight that could make the thread break also.
Good luck and let me know if these suggestions help.
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Aug 25, 2011
SOURCE: Elna 2007 sewing machine breaking upper thread in
Is your top thread tension on 1? this sounds way too loose, should be 4 or 5.
This is a horizontal top loading bobbin machine isn't it like the Janomes?
Do you have a manual for it? It sounds to me like the top thread is too loose and as it is pulled down and around the rotary hook there is no tension on it to pull it back up through the fabric and form a stitch which is then causing it to jam. Then once youve gots bits of thread in there, its just jamming and jamming. Cleaning out the bobbin holder as you described is good, you may need to do it again and ensure all bits of thread are out of it.
I think you need to revist all the threading up and ensure that the top thread is under tension, try number 5. Also check that bobbin is correctly wound nice and smoothly, then loaded into the bobbin holder correctly so that the thread is coming off the bobbin spool in the right direction, ie thread needs to come off the bobbin, then reverse direction in a "v" shape, usually in the direction of the back of the free arm. And that the thread has been clicked into the tension spring fully, put the thread into the slot of the tension device and press down on it with your finger tip until you hear it click into tension.
Also double check the take up lever, if the thread has slipped out of this, it will jam up for sure.
If you don't have any manual for this then try www.sewusa.com, there is good troubleshooting tips and threading diagrams for lots of makes and models.
Hope this helps you, persever, its most likely threading/tension issues and can be overcome with the right settings.
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Oct 10, 2011
SOURCE: Having trouble with the tension. I keep breaking
normal tension for the top thread on a sewing machine is between 4-6, usually 5. If the top thread is breaking you need to firstly look at the thread you are using; is it old and brittle or a new reel. Don't use those cheap cottons you buy 4 in a pack in a bargain bin, they shred colour and fibres and are not good for the machine. Brands to use include Guttermann, Mettler Metrosene, Molynecke, and Madeira.
If you can access them, try cleaning between the discs on the tension device. To do this, turn the tension dial to zero, then "floss" between the discs using the selvage edge of a clean piece of cotton offcut, if some gunk comes out, clean some more. You can moisten the fabric with denatured alcohol if the discs are pretty gummed out. Make sure you set tension back to 5, then thread up again and pay particular attention to the thread take up lever. This draws down the thread from the spool on its downward stroke, so is necessary to ensure smooth flow of thread from spool to needle.
Also see if the thread is catching anywhere in the thread path, it may be catching on the thread spool itself, some have a slot to hold the thread during storage. Also see if the thread has wrapped around any of the thread eyelets or part of the machine. Make sure its threaded through all the eyelets in the threading diagram, usually top eyelet, tension dial, take up lever then down to the needle.
Try all these things and see if it resolves the issues you are having, it is easy sometimes to just miss one part of the threading up, even experts do it sometimes.
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 30, 2011
SOURCE: How do you set tension
Hello, wj
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
I have a quilt expressing 4.2 and I am free motioning with the spring foot with monopoly thread and bobbinfil in the bobbin and trying to stitch around applique but the stitches are tiny way too small
If you are free motion quilting, you are manually moving the fabric while the machine stitches. You are either moving the fabric too slowly or the machine speed is too high. To get good FMQ results, you need to find the sweet spot where your hand movement equals the machine speed. FWIW, stitching with monofilament thread is difficult. You may try it with regular thread and see if the result is better.
How to successfully use monofilament thread on Janome Horizon 7700
Generally, it is better to use monofilament in the top, not in the bobbin. There is also a problem with tension so our instructor had us tape a paper clip vertically about midway between the spool pin and the first thread guide on the top of our machine, set the spool behind the machine in a small cup and ran the monofilament through the paper clip and threaded as normal.
1helpful
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
2helpful
Keeps skipping stitches and knots thread
Good day!
Good day!
I cant free motion on my viking 1+, tension is always off, and breaks threads! help.
When we get an answer to your question - I can help you celebrate. While my 1+ is a workhorse like no other, you would swear I was asking it to speak when I want it to free motion.
TO DATE: Best results (on small projects only) is using a size 90 needle with fine thread. The thread can be poly/cotton or cotton. Monofilament breaks too much. Drop feed dogs but USE THE TEFLON FOOT! MAKING SURE TO HAVE SET THE SIDE DAIL TO DARNING.
Then, this is miportant, cross your eyeballs, fingers and toes - it is a real gamble. And that Viling 1+ was NOT a cheap machine. I will keep checking back to see if someone can give us a better answer.
2helpful
Can i use monofilament nylon thread with the 1600p series machines ?
Yes. Loosen the tension a bit and then test on like fabric until you get a satisfactory stitch.
2helpful
Bottom thread is tangling and machine is stuck
This is called "nesting" and occurs when there is poor tension on the top thread. Un-thread your machine, use canned air (available at most office supply stores or any store that sells office products) and give a short blast of air into the side where the tension discs are located. Sometimes there will be a gob of thread or lint that is keeping the discs from closing all of the way. After doing this, check your upper tension to make sure it is set on the right number. For sewing with regular construction thread, such as cotton or 100% polyester, it should be set on 4. If you are sewing with monofilament thread or metallic thread, the number will be lower. The lower the number, the less the tension. After you have checked the tension, thread your machine with the foot in the UP position. One of the most common mistakes sewers make is threading the machine with the foot down. When the foot is in the up position, the tension discs are open and the thread can be fed in between them. Once you have threaded your machine and before you thread the needle, put the foot down. This closes the tension discs on the thread and keeps it from coming out while you thread the needle. Give a gentle tug on the thread. It should have good resistance. If it pulls freely off the spool, either it is not threaded correctly or you still have gunk in between your tension discs.
Now stitch out on some scrap fabric and you should have no more problems. If you continue to have nesting after doing these things, your problem could be with the type of fabric you are sewing in combination with the stitch you are trying to sew. If you are sewing with batik fabrics which have a very tight weave or with lightweight fabrics, you may have to use a straight stitch plate or wash-away stabilizer. Hope this helps!
2answers
Monofilament thread nesting up underneath
Mono thread can develop a memory and curl itself around things. I hate the stuff.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
