Can I adjust headlights myself? Right low beam aimed too high...
SOURCE: headlights come on when ign key turned on without
that model of mercedes did come out with daylight running lights meaning that when the key is on the headlights come on at a lower wattage. and if your bulbs keep blowing i would have the wiring checked out.
SOURCE: difficulty changing a low beam lamp on my 2002 mercedes c320
FIRST DISCONNECT THE LIGHT FROM THE POWER ON THE LAMP YOU ARE TRYING TO REPLACE. It is a plug type that will pull as the sides are pushed. NEXT, The light will have a WIRED brace holding it on. Look closely. Pushed the WIRED brace at an angle and wiggle it. After it comes off and hangs there like a latch, turn the receptacle of the actual light counter clockwise and it will come out. Replace bulb and do the same thing opposite of what I explained.
SOURCE: 1994 Mercedes c280 high beams not working...
headlight relay is under the screwed down portion of the fusebox.
