Roper RAS8445KQ Top Load Washer Logo
A
Anonymous Posted on Feb 23, 2015
My roper washer that filled with water and then stopped.
Loader the washer and it filled with water then quite working will not do anything at all
dweatherby
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on May 08, 2017
dweatherby
Expert
Level 2:
Sergeant:
Answers
239
Questions
Helped
90549
Points
511
Most likely a bad lid switch
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on May 11, 2008
SOURCE: my roper washer won't fill with water
check the water inlet valve
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 11, 2008
SOURCE: Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
Anonymous
  • 5911 Answers
  • Posted on May 27, 2009
SOURCE: Washer fills with water then does nothing
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Anonymous
  • 5911 Answers
  • Posted on Jul 05, 2009
SOURCE: roper washer stopped mid-cycle full of water
NOTE: You do not have to drain the washer to complete this repair. Once the lid switch is adjusted or replaced, the water will drain. This will save you time in having to bail water.
Anonymous
  • 126 Answers
  • Posted on Nov 24, 2009
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
I have washer Roper SM 8525493. It will only fill with water when in rinse cycle. Any help would be greatly appreciated. Thanks
comes up my part of the world as as a whirlpool brand of top loader
the actual timer is faulty
water inlet valve must be working to let water in
but timer opens and closes that inlet valve
http://www.repairclinic.com/Shop-For-Parts/a11b122/Roper-Washing-Machine-Parts
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
1helpful
Cold water wont quit runnin after machine fills up
You'll have to replace the water inlet valve. Hope this helps!
2answers
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
2answers
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
