Suspension & Steering for Kia Sedona Logo
A
Anonymous Posted on Feb 23, 2015
How do I get the motor to turn off?
THe motor will not turn off and runs continually, how do I get it to turn off?
perrymanea
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 24, 2015
perrymanea
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
2881
Points
43
Try disconnecting the battery?
Room fan operates continually
the capacitor is correct for the motor
all it does is supply an over voltage burst to start the motor turning, then to keep it running while the switch is on
if the capacitor was faulty in the original motor then the motor will burn out as that over voltage is not there but the current to run the motor is so the motor over heats and burns
as to the constant running it is important to check how you attached the wires to the new motor as you may have a power wire direct to the motor instead of through the switch control
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Tumble dryerdrum not turning when on but motor continues to run when door open
Does the drum turn by hand? I would check the motor belt first
Motor continues to run after machine has been switched off
If it keeps running after you unplug it, you have somehow gotten your hands on a perpetual motion machine. Use it to run a generator and sell electricity to your neighbors!
Seriously, I think you meant "after you turn it off at the washing machine control panel." You probably have a shorted motor contact in the timer (contacts welded together).
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
Ice dispenser will not stop. Motor continues to run even after re
hi there,
replace the lever switch it was already defective it always contactor normaly close,let the qualified techinician do this for you.
besure to unplug the unit before doing this.have a nice day.don't forgety to rate me,thank's a lot
Replaced blower motor, now runs continuously.
Run's continuously ? High speed , low , med 1,2, 3 . ????
Probably the high speed relay contact's stuck closed . The fuse for the high blower is hot at all times , low blower fuse is hot only with key on. It sparks becaused the motor turns on . If it had a short the fuse would blow . The blower motor relay is part of the resistor pack near the blower motor .
1997 Saturn SW2 Windshield wipers won't stop.
Wiper Motor Switch Troubleshooting Check out someother GM wiper fail's video's ,not shuting off means the park switch is bad inside the motor assembly ,u need a new motor .
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
