Toshiba Satellite Pro L300 Notebook Logo
A
ALFRED Posted on Feb 23, 2015
HOW DO I GET RID OF hdd builtt-in password
PLEASE ENTER BUILT-IN HDD USER PASSWORD THATS THE ERROR MESSAGE AM GETTING
2 Related Answers
Anonymous
  • 532 Answers
  • Posted on Mar 27, 2010
SOURCE: Is there a way of fixing this
Hard drive passwords are embedded in the firmware of the drive itself. You need to try to find out what the password was.
If you put in a new drive, that drive will not contain the password routine. It is the physical drive that is password protected, not the system.
There is an article about this at this site.
gregmen83
Jose Mendoza
  • 199 Answers
  • Posted on Dec 10, 2011
SOURCE: please enter built-in hdd user password
Dear Friend,
You need to update your BIOS driver. You can achieved this by visiting your computer manufacture website and look for support center then, in the download section you should find the BIOS driver. Make sure you follow all the required steps to do this.
Good Luck!
Forgotton hdd password on Toshiba satalite oro a210
you could try this,,,Others have been able to change the password in BIOS. Found this:
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice
Remove password hdd toshiba mk3275gsx
HDD Password
HDD = Built-in HDD
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice.
Hope above steps helps you. :)
Built-in hdd user password
These WEB sites may help you remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Please enter built-in hdd user password
Dear Friend,
Good Luck!
4helpful
2answers
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
11helpful
6answers
Need to bypass primary master HDD user password
send me ur email and I'll give you link for software to remove all passwords in bios or windows
1helpful
call the acer tech support or go on line a to www.acer.com and they should be able to get you need best regards mike
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
