Keeps powering up and then shutting down. apps and google pay stop unexpectedly
Go to www.blogs.msdn.com/Rohitsblog
Gives detailed instructions on how to do a factory reset.
http://www.blogs.msdn.com/Rohitsblog
SOURCE: why my htc hd phone keeps shutting down
There must be some kind of virus in your mobile and need to reinstall the software of the mobile which you can get from local mobile repair show or you can also contact HTC for it as there is no other way
SOURCE: touchflo (process com.htc.launcher) has stopped unexplectedlu
All i did was take out my SD card and wait 15 seconds then put it back in the phone. I did not see the process com.htc.launcher error anymore.
SOURCE: I recently have updated a
Hi mistybates1,
Please install "Log Collector" from Market. Next time this happens, please start Log Collector immediately and send your log data to [email protected]. This way we may find out what's actually going on and hopefully fix it.
- Stig from Zedge
SOURCE: on HTC Hero msg occurs
The best thing to try is to do a factory reset on the phone to get it back to factory status. I've had to do this on my Android phone a few times. make sure to back up your data first. After you do this, see if you can access your accounts on Google before installing anything else.
SOURCE: htc wildfire will not load free apps from google
Your provider may have locked your phone to prevent it from installing applications that are not downloaded from the Market. To load apps on your phone, select the Market application from your App Drawer and download applications from there. These approved apps will work with your phone.
If this helped you, help me with a few thumbs up!
Testimonial: "problem sorted thanks "
2. Press and hold Volume Down and Power.
3. Keep holding both buttons until you see the Android logos appear on the screen.
4. Use the Volume Down button to toggle the selection and highlight Factory Reset.
5. Use the Power button to choose Factory Reset.
The HTC Inspire 4G will then complete the hard reset process. SD card data like music and photos should be preserved.
Software method
If you can boot into the device, you can use this option.
1. Tap the application slider and select the Settings app.
2. Select SD & phone storage.
3. Choose Factory data reset.
4. Select Reset phone.
5. Select Erase everything.
