SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
SOURCE: Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
SOURCE: MAYTAG LEGACY MODEL # SAV205DAWW
I've got the same problem. The diagram is a bit deceiving because it appears to show the agitator/auger as one piece. However, the bolt only holds the agitator (lower portion) and then the auger slips in place over that. The fabric softener cup then snaps to the top of the auger.
Best I can tell is that the slotted 'ears' on top of the agitator are worn thus preventing a secure fit between the agitator and auger. I just finished putting some hard thumb pressure on each of the ears and bent them outward some. The auger fits much tighter now and I'm doing a test run of clothes. It is holding but I will probably have to replace what they describe as the agitator / auger assembly, costs $53.54. I don't see any other fix but would appreciate further input.
Thanks
SOURCE: SAV205DAWW Maytag Washer Belt Replacement Instructions
First comment: mrton
There are four bolts holding the motor to the chassis. Remove the four bolts, slide you hand back along the belt and released the belt from the transmission pulley. Once this is done, turn the motor and pump upside down and you will see the three star screws that hold the pump on. Remove the screws and slide the pump off. If the pump is stuck you will have no choice but to break the pump off and replace it.
Second comment:Guest
I'm sorry you have had such a hard time with your Maytag washer. The problem may very well be a cracked pump or leaking tub seal.
As to a replacement ? All machines have pros and cons and can be difficult to choose. I'd look at a Whirlpool for two reasons. Price and ease of repair. Most whirlpools do suffer minor problems as time goes on but very few have major breakdowns.
