Crossed wires or bad ground
Make sure your rca are not up against any heavy metal or pinched by something. cheap rca cables have no type of insulations coating and when up against metal will cause interference. mine did the same thing when I ran it up against the seat belt bracket... pull it out from where you have it routed from but leave it all hooked up and see if it still MAKING the same noise if it goes away then try reroute or get better rca and make sure no pinched wire hope this helps .... always go with good rca cables
SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
SOURCE: make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
