The tail light fuse in a 2012 Ford Fusion can be found in the fuse panel that is in the cabin on the driver's side under the steering wheel. The fuse should be number 22 but always check with the cover that is over the panel to confirm. If Your tail lights are out on Your Fusion the first thing You should check are the bulbs. These burn out regularly and are a consumable part. If they are okay then the next thing to check are the fuses. If the fuse is blown go ahead and replace it and make sure the lights work. If You are popping fuses regularly to Your tail lights then there is likely a short in the wiring to them.
you can google 2012 ford escape fuse diagram for more info
copy and paste link
2009 Ford Fusion ... Front Proc 1 Note ... Front Proc 2 Note ... Do not attempt to tighten the nut with the vehicle on the ground or the wheel bearing will be ...
Dec. 2, 2019 - Im replacing the front wheel bearing assemble this weekend and cant find the torque spec for the ale nut. The older model Fusion (up to 2012) ...
This had been an intermittent problem on my 2012 Fusion, but the other day it became permanent. I have since discovered that the Fusion has electronic power steering, that this problem is caused by a bad module, and that the fix involves replacing the entire rack and pinion system.
2008 Ford Fusion Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Green Car Radio Ground Wire: Black/Blue Car Stereo Antenna Trigger Wire: Purple/Black Left Front Speaker Positive Wire (+): White Left Front Speaker Negative Wire (-): White/Brown Right Front Speaker Positive Wire (+): White/Purple Right Front Speaker Negative Wire (-): White/Orange Left Rear Speaker Positive Wire (+): Brown/Green Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Brown/White Right Rear Speaker Negative Wire (-): Brown/Blue
Chances are you have a shorted output or partially / completely blown speaker. Check all speaker output impedances. If one of them is significantly lower, disconnect that speaker/output and try turning the bass up again. If it works fine, trace that wire to the short or blown speaker. If all impedances look ok, or disconnecting that output doesn't help, then it's time to rip the unit apart and diagnose the amp.
try using a ohm meter and if its not making what the factory specs are its most likly it will keep loosing more and more power then stop working which is what ive had happen to me before
You need to install a heavier gauge wire to your amp and a capacitor.
It works fine at low volumes because there is enough wattage from the
battery to power the bass output of the amp but at higher volumes the
amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve
of wattage for the amp to use so that it does not run out while
blasting your tunes.
