Question about Vehicle Parts & Accessories
How do i get free gem
I need gems for upgrading something.
    Top Expert:
  • Vehicle Part... Master
  • 5,292 Answers
What are gems?
Posted on Feb 26, 2019
SOURCE:
  • 4 Answers
SOURCE: Gem Sound CDM-150 Dual cd player
try this manual it's the same all in one mixer - http://www.geminidj.com/product_manuals/CDM-500_om_12_7_2005_small.pdf
Posted on Apr 25, 2009
seans46
  • 161 Answers
SOURCE: Location of GEM Module on 1998 Ranger
i am almost sure it is in steering col area by firewall. but call any part store like auto zone and they can print it out and tell you if your ford dealer wont. but on the fords they usualy are all in the drivers steering area sometimes way up by fire wall
Posted on Jun 15, 2009
  • 27 Answers
SOURCE: think i got water in my GEM the lights will not go
The GEM is located behind the radio, so you would have had to pull a real no no to get it wet. Most likely, a sticking door ajar switch is you culprit, very common on Ford vehicles, the bad part is they are located in the door latch and can be a bear to replace.
Posted on Jun 24, 2009
Dissolu
  • 221 Answers
SOURCE: instruction manual for service gem 1000 washing
I know the place where to get it for $10. If you won't find anywhere else, just let me know
Posted on Jul 25, 2009
  • 183 Answers
SOURCE: Gem Module, Fuse Box and Window Reseal
This 1997 Ford F150 needs the GEM module changed due to multiple conditions. To see testing that lead to this repair please click here. The GEM module is located t the rear of the interior fuse box.
The first step is to remove the trim panel that covers the gap between the upper side of the steering column and the dash. It just unsnaps from the dash. It makes it a little easier to remove if you move the shifter all the way down to drive 1.
With that out of the way the lower dash cover can now be removed. Most of the screws have 7 mm heads but there are two that have 8 mm heads.
Those two are at the lower edge of the fuse box.
One wiring harness needs to be disconnected from the panel.
Now the screws for the fuse box can be removed.
The wiring harnesses can be removed from the back of the fuse box. Two 10 mm headed bolts at the center of each connector.
Next remove the tube brace from around the bottom of the steering column. Four fasteners with 13 mm heads.
Now wiggle, pry and twist the fuse box and GEM module assembly down.
After the assembly is down far enough unplug the remaining harness connectors from the GEM module.
Almost there.
The assembly is now free of the vehicle.
The GEM module is held to the back of the fuse box by three phillips headed screws.
Easy to remove Now.
With the three screws removed the GEM unplugs from the back of the fuse box.
I put it all back together and checked my repair for power to the driver's power window switch.
Posted on Jan 10, 2012
I need a free animal jam code.
mabe you should earn codes but i will give ya a few here they are explorer - 100 gems ngkidsrox - 1000 gems discovery - 1000 gems AJBDAY3 - 3rd Birthday Cake bemybuddy - 500 gems AJHQ3000 - 500 gems 10million - 10 Million Banner
ngexplorer - 1000 gems
drawing - 500 gems
hooot - 500 gems
alphas - 500 gems
kangaroo - 500 gems
koala - 500 gems
dolphin - 500 gems and thats all the codes you will need
Aug 25, 2013 | Vacuums
Vehicle Parts & Accessories Logo
96 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
