Question about Hyundai 2009 Santa Fe
What makes my 2009 santa fe gear shift sorta stiff to move
Shift lever in consel stiff when changining gears and sometimes will not start in park
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 68 Answers
Hi
This condition is usually caused by the transmission gear shift tower
seizing up in the inhibitor switch. To correct this, the gear shifter cable will have to be taken off at the transmission end which is fasened to the shift tower. Then remove the inhibitor/range switch and unseize the shift tower, working it back and forth with antiseize lub. Once the tower is cleaned, lubbed and has free movement, install a new range switch and reinstall shift cable if it is okay. Note: reinstall range switch in the same position as the old part so the start settings for park and neutral are good.
Posted on Feb 23, 2015
SOURCE:
Chevrolet Caprice Transmission Will not shift to overdrive
Check the help link mentioned below:----
Overdrive light in the dash blinks?
http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Have a 2003 Dodge Intrepid. I can't get the shifter on the column to move out of park even when I move the steering wheel up,down & side to side. Is it the cable, the link, what?
The shifter needs to be inspected. The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities. But if it was working right up till now and suddenly this occurred then its shifter assembly alignment issue.
GEAR SHIFT ISSUES
Thanks.
Nov 28, 2012 | 2000 Dodge Intrepid
Toyota Tercel stuck in gear
Its a gear shift issue.
GEAR SHIFT ISSUES
Thanks.
Nov 28, 2012 | 1993 Toyota Tercel
56 ducato van wont go into 1st 2nd gear easy
GEAR SHIFT ISSUES
Thanks.
My scond & fourth gear is grating
GEAR SHIFT ISSUES
Thanks.
Nov 27, 2012 | Cars & Trucks
My 2008 Chevy impala will not come out of park
The
shifter needs to be inspected. Its quite possible that The
There
suddenly this shifting problem occurred then its shifter
Also
the specific problems of gear shift
GEAR SHIFT ISSUES
Gear
Park?
gear?
Car won\'t downshift sometimes?
No
Ford Taurus won\'t shift from park?
is turned ON?
Issue?
mornings?
driving?
Park Mode?
Thanks.
Nov 26, 2012 | Cars & Trucks
2003 chevy suburban 4wd 1500 lt shifts slow to 2nd gear and vibrates between 65 and 70 mph
Sounds to me that you need your trans fluid changed and filter. When you do change it use a quart of Lucas transmission conditioner to it. Also check and see if you may have a bad univercel, It will also make it vibrate at faster speeds or your drive shaft may need to be rebalanced.
Nov 25, 2012 | Chevrolet Suburban 1500 Cars & Trucks
Shifting when driving
The shifter needs to be inspected.If the gears are shifted automatically.The shifter assembly is got misaligned,it has to be open and realign.
There are many other possibilities.But if it was working right up till now and suddenly this auto shifting occurred then its shifter assembly realign issue.
Also i suggest you to refer these gear shift issues,which are mostly noticed.These are direct links with appropriate solutions to the specific problems of gear ****.
Click the link below:------
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
----------- Automatic transmission will not go into high gear?
-------- Buick Park Avenue: Transmission will Not shift into drive?
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
-------- Third gear missing and engine losing power?
-------- Chevrolet silverado has whining sound in gear?
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
-------- Car hard shift at slow speeds?
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
------------ 2000 Nissan maxima shifts hard?
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
==========These details will help.Thanks.
Nov 24, 2012 | 1995 Mercury Mystique
Renault trafic 100 dci gear selector
There are few related help links related to gear shift issues:----
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html Car will not come out of Park?
No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html Shift indicator directly goes to 2nd when key is turned ON?
2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html Hard to shift gears on Manual transmission?
Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html Automatic transmission shift lever hard to move on cold mornings?
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
94 toyota is over 3000 rpm at 40 mph
It can be the issue with Transmission or problem with gear shift assembly.The system has to be inspected and tested.----------
For complete step by step troubleshooting,click the solved help links with complete solution for such various solutions.
-------------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
------------ 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
------------ Car will not move when in gear?
------------ Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
------------ Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
----------- Chrysler PT Cruiser only goes in First gear?
----------- Car will not come out of Park?
---------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
----------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
----------- Car Transmission will not go into Park mode?
----------- Shift indicator directly goes to 2nd when key is turned ON?
---------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Thanks.
Oct 16, 2012 | 1994 Toyota Paseo
Hyundai 2009 Santa Fe Logo
1,653 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
moony
Level 1 Expert
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
