If you had a "Bose" sound system - Factory installed - it should have and Amplified System - which means the original stereo will supply power to the Speaker Amps - that is the circuit that didn't get connected and why there is no sound.
I hope that resolves your issue
Thanks
Testimonial: "Is there a different wiring harness to buy? did i just miss a wire, or do i need to bypass the factory amp?"
most often the circuit is there with the aftermarket radio
"Antenna motor on" or "Amp On" is the output you need - both will apply 12 volt signal with radio ON.
Not sure about the one you need to connect to on the car - however after all the other necessary ones like for speakers - key on power - memory power - ground - there are not too many circuits left .
I seem to remember blue for Chrysler products.
Let me know if that helps
thanks
