SOURCE: Flush assembly
http://products.jacuzzi.com/nd/viewone_07.d2w/description?SCIN=T&SGIN=ERAELONGATED
Follow the link above. You will find a link to a dealer in your area that will have the proper parts for your toilet. Often these toilets have brand spacific parts for them. The poblem with places like Lowes, in regards to their employees is that they are not trained to know the details about repair. Most of these people have never been in the industry in which they are selling products for. Also, most homeowners arent concerned about how they are going to repair this product at the moment, just how it looks at the time of purchase plus most homeowners don't repair their own, they hire it done. Hope this helps.
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
SOURCE: Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
