SOURCE: How tight is the tank/bowl supposed to be a
They only need to be tight enough to sufficiently seal the donut between the tank and the bowl. Some movement is acceptable. It is better to be a little loose than to overtighten them and risk cracking the tank.
SOURCE: how to assemble tank to bowl
Good Luck and have a Great Day. Please give a 4 THUMBS UP if this free answer was helpful. THNX
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
SOURCE: i need to replace the wax seal on my jacuzzi
I would just use the one from hardware store. nothing special about the wax from the manufacturer except the price...
be sure to do a thurough cleaning on the bottom of the toilet and make sure it is dry before you install new wax ring or it will leak.
you can actually use a hair dryer or set it in the sun to soften the wax ring, don't melt it, just soften it. makes a much easier time when setting the toilet down onto the wax.
