Do you mean the Carlon RC4120 wireless battery door chime? If so, press the small button below the chime button to hear the next tone or melody selection. Wait until this melody is finished playing before pressing the button again. Repeat the press the button and wait for the melody to play, as needed to get a melody/tone that you like. To save the current selected melody or tone, do not press the small button again.
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Mary, there is a small button on the face of the face of the pusher. With the unit plugged in, push that little button and it will play the next available ring tone. When you find one that you want to use, simply stop and that one will be what you hear when someone comes to the door.
It would appear that there are pins in both the ringer and door button and you have to change them so they match. To remove the door button, slide the case straight up slightly (maybe 1/8 inch). Pry the top of the case away from its base and slide down to remove the entire button assembly. The pins are inside, next to the battery. 5/6/7 seems to be the default, so any other combination of three pins should solve your neighborhood conflict. (Don't use pin 8. That one changes the ring from a two-tone chime to a 16-note sequence.)
