Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
<b>Amana:<br /></b>
<ol>
<li>Press and hold the <b>dispenser lock</b> and <b>auto light</b>
buttons on the dispenser for 4 seconds until the filter
status indicator begins to flash, then release the buttons.</li></ol>or<br />
<ol>
<li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br />
<ol>
<li>After replacing the water filter, press and hold the Reset Filter pad
for 3 seconds. The Order and Replace indicator lights will blink and
then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br />
<ol>
<li>Press firmly and hold start button for 5 to 10 seconds.</li>
<li>Four
bars will appear in the display, one after the other, and flash. Do not
release the start button until the 4 bars appear and start to flash. If
you have difficulty pressing the start button, a capped ballpoint pen
may be used to press the button down.</li>
<li>A small flashing dot in the lower right corner shows the indicator is working.</li>
<li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li>
<li>After
2 months, when all bars have disappeared, an arrow will flash at the
top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b>
<ol>
<li>Press and hold the <b>reset </b>button on the dispenser
until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b>
<ol>
<li><b>P</b>ress and hold the <b>reset water filter</b> button
on the dispenser for 3 seconds.</li></ol>or<br />
<ol>
<li>
Press the reset button on the dispenser for 4 to 8 seconds then release.
</li></ol><b>Hotpoint:<br />
</b>
<ol>
<b>Jenn-Air:<br />
</b>
<ol>
<li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b>
<ol>
<li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br />
<ol>
<li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br />
</b>
<ol>
<li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b>
<br />
<ol>
<li>
Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol>
<b>Maytag:<br /></b>
<ol>
<li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br />
<ol>
<li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br />
</b>
<ol>
<li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press
these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li>
<li>Release the buttons and repeat the same step one more time. The water
filter indicator light should turn green.</li></ol>or<br />
<ol>
<li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br />
<ol>
<li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i>
buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br />
<ol>
Refrigerator - Water Filter Indicator Light Will Not Shut Off
After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
First you need to replace your water filter. After you have done that, you will need to reset the water filter indicator light. Some fridges have a reset button, other fridges have a reset "procedure", often times pressing two buttons simultaneously. You didnt give me a brand or model number, so i cannot help you with how, other than to read your owners manual.
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
Water Filter Status Indicator Light (select models)
red, it will remain red until function is reset. To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
