The phone used to ring but no longer rings. Is there a setting that turned the ringer off. I have looked at the manual but only see a way to adjust ringer volume - not turn it off
SOURCE: AT&T Model#972 How to lower ringer volume?
Hey how are you ??? sorry I didnt see your post til today I'm supridse no other experts didnt reply to it :(
Any way here is your user manual
http://qwest.ettp.net/reference/ATT%20Model%20972%20Manual.pdf
and to solve your problem
When not on an a
call press a LINE
button, then press
VOLUME + to
increase,VOLUME
- to decrease
volume of the
ringer for that line.
View manual for details.,,,
And again I apoligise for the late reply Sir ,, I do hope all is well with you .. Regards
SOURCE: phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
SOURCE: ATT/Lucent 854 ringing after power outage
Press PROGRAM
Press *
Press #
Enter 2 digits (11 through 22)
Press INTERCOM
This should work.
SOURCE: Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension
rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a
20-second delay), or No Ring.
Delayed Ring is useful for backup coverage on shared lines or pools, such as for
secretaries who cover each other’s lines. No Ring is useful for all extensions
except 10 when an operator answers all calls, or for telephones with no regular
users, such as those in conference rooms.
To change the way outside lines or pools ring at an extension:
1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line
Ringing settings for all lines or pools assigned to the extension. (If a line or
pool is not assigned to a button, the green light next to that button is off.)
The following ringing options can be shown by the green light next to the
line or pool button:
• Immediate Ring — on steady
• Delayed Ring — flashes slowly
• No Ring — flutters quickly
• Immediate Ring is the factory setting for lines; No Ring is the factory
setting for pools.
3 Press the line or pool button until the button light shows the correct setting
(the setting for the currently selected line or pool also appears on the
display).
4 Continue programming, or exit programming mode.
SOURCE: my ATT 955 phone had a powerfailure and now the
Sounds like you'll need to setup the intercom number again.
Assign an Extension Number to Your Phone
1 Press program.
2 Press the down arrow until the screen displays EXTENSION NO, then press the right arrow.
3 Press the down arrow or the up arrow to select the desired extension number (from 11 to 22).
4 Press the save button to store your selection.
NOTE: If you duplicate an extension number, you will hear a repeating
short ring. Repeat Steps 1-4 and assign a different number (from 11 to 22).
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
