For beginners in the Astronomy hobby we usually recommend that they buy a nice pair of either 7x50mm binoculars, or 10x50mm binoculars as their first 'telescope".
Additionally they should buy one or two Astronomy books, one of which should be a star chart. You will use the star chart and the binoculars to learn a little bit about the night sky BEFORE you buy your first telescope.
Good books:
Objects in the Heavens by Peter Birren- http://www.amazon.com/Objects-Heavens-Peter-Birren/dp/155369662X/ref=sr_1_fkmr0_1?ie=UTF8&qid=1264187389&sr=8-1-fkmr0
Sky & Telescope Star Atlas- http://www.amazon.com/Sky-Telescopes-Pocket-Atlas/dp/1931559317/ref=sr_1_1?ie=UTF8&s=books&qid=1264187432&sr=8-1
Turn Left at Orion- http://www.amazon.com/Turn-Left-Orion-Hundred-Telescope/dp/0521781906/ref=sr_1_1?ie=UTF8&s=books&qid=1264187469&sr=8-1-spell
Spend a few months learning the sky with the binoculars and JOIN a local Astronomy club. The members will help you learn the sky and you will get to look through their telescopes and decide on which one you should purchase. Did you know that the Astronomical League gives awards for completing several different observations using binoculars! Join your local AL Astronomy club to learn about observing awards using only binoculars!
List of Astronomy Clubs by State: http://www.astroleague.org/societies/list
Objects in the sky are VERY TINY- no larger than the tip of your finger held at arm's length! You must be pointed directly at them to see them. Buy several good astronomy books like- "Turn Left at Orion", or "Nightwatch".
Join a local astronomy club and the members will help you FIND objects in the night sky.
Press INTERACTIVE button on your remote then option 5 then 5 again follow the on screen prompts. This will ask you the make and model number ie 19g07no2g-785
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
