Mitsubishi WD-65735 Television Logo
S
Sharon Van Dalen Posted on Feb 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix pixels on my tv screen
White pixels all over TV. Purchased 2008, cannot find any solutions within setup options to fix. Is it worth fixing ??
HawkLore
Level 2:
Scholar:
  • Expert 98 Answers
  • Posted on Feb 21, 2015
HawkLore
Expert
Level 2:
Scholar:
Answers
98
Questions
0
Helped
33758
Points
389
Usually solved by replacing the DLP chip (Google it) they cost around 180. If you have a couple hundred more I'd just go buy a Samsung LCD smart tv.
Tv Vizio Model E50-C1 dark spot?
Sounds like dead pixells to me.
Replace the screen if it is worth it.
2answers
White spot on screen
Sounds like you are describing stuck/dead pixel.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel
Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
1helpful
3answers
Insignia 26 inch TV/DVD Combo produces strange odor when on.
You should never have an acrid or burning smell coming from electronics. I'd return the unit, if that is still an option, as it is about to fail.
2answers
Pixel gone
No this is whats called a dead pixel. Since it's white the transistor at that pixel area is shorted. Depending on the age of the unit the manufactor may replace the unit if not the whole panel will have to be replaced at a cost of more than the unit cost. Most manufactor says more then one pixel has to be bad before they will do anything.
Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
10helpful
9answers
White screen problem in acer aspire 4710
You will have to disconnect and reconnect the video signal plug located under the upper cover (the one with the power button on it). Best you start with a screwdriver in the very corner).
See also: http://blog.shimpossible.com/2007/07/18/white-screen-of-death/
Additionally I removed a small magnet located under the lid cover (remove 6 screws under rubber placers and lift the lid), which I found next to the video cabling. This could have affected the video signal negatively. Lets see how long this fix lasts.....
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
