Roper RAS8445KQ Top Load Washer Logo
A
Anonymous Posted on Feb 20, 2015
How do i bypass the lid lock on a roper machine
The system tries it chicks but does not lock so i can't use the machine. I would like to disable the lock so I can use the machine
dweatherby
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on May 08, 2017
dweatherby
Expert
Level 2:
Sergeant:
Answers
239
Questions
Helped
90476
Points
511
Two screws to remove top panel. 2 clips to remove cabinet . remove lid switch . of course unplug machine.
2 Related Answers
Anonymous
  • 254 Answers
  • Posted on Feb 14, 2010
SOURCE: my roper washing machine stops working but will
it sounds like the lid switch, get ur model number and purchse one online at repairclinic, or sear, or locally.. hope this helps, i think ur on the rite track bukaroo let me know how it goes
Testimonial: "I'll give this a try, thanks for your help!"
Shep
  • 22 Answers
  • Posted on Feb 12, 2015
SOURCE: how do i bypass the lid lock switch with four wires on the Roper Washing Machine?
First off you shouldn't!!
you may cause more problems and cost !
more important if you want someone to answer your question a model number is needed !
Can I bypass the lid switch on a Roper RTW4516FW2 washing macine
On this model you cannot pass the cover lock / lock assembly and, if you do, you should disconnect it with each wash cycle so that the control panel sees the cover as open.
2answers
How do I DISABLE the lid lock switch. I can't wash clothes.
Replacing it is a better option. Depending on your model, problem may be something else.
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Can the lid lock be bypassed?
Yes you can turn washer upside down find switch cut the wires twist together and tape up bare wires
One problem you have disabled a safety feature with risks to your or other user safety
Is it a lid or door lock you want to disable if it is a door lock switch risk of flooding rooms is higher
How do i bypass the lid lock switch with four wires on the Roper Washing Machine?
2helpful
Hello, my roper washer filled up with water but will not do anything else.
Check/replace the lid switch - modern Roper machines are direct drive. You can bypass the switch (join the contacts with a conductor) but it is a safety feature for a reason.
2answers
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    5helpful
    3answers
    Washing machine lid switch
    Can you bypass the lid switch on a roper washing machine?
    Top Roper Washing Machines Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
