see if this helps you out.. To resolve this you need to alter the port that your iPhone or iPad uses to send mailwhich can be done as follows. Go to Mail, Contacts, Calendars and select the account you wish to change. On the next screen, scroll down to the "Outgoing Mail Server" section and select the SMTP server that is listed.
You should check the settings required by your mail supplier. Have a look in Google for your Mail Settings for the YYYY.ZZZZ after the @ in your mail address.
Follow their instructions EXACTLY or contact your mail supplier for these details.
You can always restore it to brand new.
You need a computer with iTunes and the charghing usb cable.
Before restoring make sure that the Find my iPhone app is off, otherwise after restoring it will give you the very same wrong email.
Once that is off, connect the ipad to the computer and click restore.
Once restore is complete, at very end you will be prompt with 2 questions:
1. Set iPad as brand new
2. Restore from (your name) back up.
At this iem you can choose either one, because Find my iPhone is off. And now you can change the email address.
It is your best option since it is way too difficult without restoring it.
first of all, never, never, never post your actual email account on a public website, unless you want a bunch of weirdo people to start texting and sending you emails. Secondly, there should have been security questions only you could answer in order for them to send you a temporary passcode. They would send it directly to either a cell phone or an alternate email account. If you didn't set up these precautions; I suggest you either set up a new account or contact the Hotmail people and reset your account passcode through them. You can do this on a laptop or home computer. "Contact Us: or Forgot my Password:"
Hi Michelle.
before you send the mail.
select all and select copy .then it will copy to clipbord or what ever.
after you sending it will faills ,just go to new email and select paste .
hi,
please copy the message by selecting all of its contains before press send button.
if same error came up.you can compose new mail and paste the things and ready to go..
anyway try to reset your device for this error.
if doesn't help use coustom rom installation.if you want more infomations go to XDA forums.
regards.
nuwan
Email accounts can be hard to sort out if you don't know what you are doing. Have you thought about changing your email address to someone like Hotmail, Google, Yahoo. It is easy to register with them and you should need to do anything for them to work properly. What sort of PC are you using? It will help if I know so I can answer the question about copying and pasting. With a laptop you put your pointer to the start of the text you want to copy and then click on the left side of the trackpad and keep pressure on and move from left to right until all the text you want to copy is highlighted. You can now let go of the trackpad and press you Command key + C or go to the menu bar and select Edit and then Copy. The url is now copied, now to paste you put the pointer to where you want the url to be and simple press command Command key + V (on a Macbook) or go to Edit again and select paste from the drop down menu. You should now have copied and pasted your url? Hope that is of help.
