Dishwashers Logo
A
Anonymous Posted on Feb 20, 2015
How do I determine why my Frigidaire fdb510cfs0 will not start when turned on??
Will not turn on when door is closed and cycle set???
  • Official Brand Answer 2,267 Answers
  • Posted on Feb 23, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288905
Points
2557
Hey friend, thank you for your post!
From what you have described your Frigidaire dishwasher, FDB510CFS0, will start operating. This could be a possible issue with your control panel or door latch. If you door is not latching properly then it is not sending the appropriate signals to your control panel. This could cause an error code to populate. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from it for roughly ten minutes. Hopefully this is helpful to some degree. -Matt
Lights keep blinking-washer won't start
Good Morning Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with your Frigidaire washer not starting. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your washer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best!
My Frigidaire Dishwasher Model #FFBD2411NWOA won't turn on at all. I flipped the breaker switch and also checked the disposal which is on the same breaker. That is working. The dishwasher was working
Good Afternoon Friend, this is Z. Thank you for your post!
I understand your Frigidaire dishwasher (FFBD2411NW0A) will not start. Let's try resetting your dishwasher by flipping the household circuit breaker to the off position once again. It is necessary to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. Best!
Wont start fdb405olhso
Hi Friend, thank you for your inquiry!
I interpret that you are having trouble with your Frigidaire dishwasher (FDB4050LHS0) not starting. Let's try resetting your dishwasher by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. Best regards! - Z
Frigidaire dishwasher- panel lights up , but it won't come on. The cancel/drain button works, but not the start button.
Hello Friend, this is Z. I am happy to assist you!
I understand your dishwasher will not start. Let's try resetting your dishwasher by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps!
We have a new Frigidaire FASG7074NR2. It stopped at the beginning of the cycle and read door open. The door was not open. We tried opening and firmly closing the door and unplugging but it still reads door...
Good Morning Frances,
I understand that your new Frigidaire dryer, model# FASG7074NR2, stops at the beginning of the cycle and states that the door is open. I also see that opening the door firmly, closing the door firmly, and unplugging your appliance, the display still reads "Door Open", and will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine why it is stating "Door Open". I hope this is helpful.
-Best Regards-
WP
Dryer door pops open during cycle
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Start button not working
Good Morning Friend, thank you for your post!
I see that your Frigidaire dishwasher has power but will not start a cycle. Let's try resetting your dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Best regards! - Z
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
2answers
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
