Casio Electronic Financial Consultant Calculator FC-100V Logo
O
Ola Roedningsby Posted on Feb 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i turn a decimal answer into a fraction answer on my Casio FC-100V. The calculator does not have the SD button
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jul 03, 2015
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671812
Points
21595
It is a financial calculator, not a scientific one.
1 Related Answer
Anonymous
  • 8 Answers
  • Posted on Feb 05, 2011
SOURCE: fc-100V financial calculator can't get
I have the same problem here is what I did.
1. Press mode at the top.
2. Press the number 1
3. Done
Simple.
P.s some models are different so try 2 and 3.
1helpful
CASIO fx-9750GIII: Convert decimal answers to complex fractions?
to save time, I would suggest switching calculators and also recommend using an online scientific calculator to reach your goal. If the manual for your device is bad, you can look into getting a new calculator. Thank you.
2answers
Fraction to decimal
Press the S<->D button located just above the DEL button.
I need to know how to change a decimal answer to a fraction answer
Press the S<-->D button to switch between decimal and fraction displays. Bear in mind that the calculator can not display all numbers as fractions.
Fc-100V financial calculator can't get answer as a fraction, only as decimal
3. Done
Simple.
6helpful
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
14helpful
Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
2helpful
2answers
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
8helpful
2answers
When I divide, it turns the answer into a fraction. How do I get back so the answer will be a decimal? With a Casio fx-115 ES
Press the S<>D key, (located right above "DEL"). This will shift the answer from fraction to decimal. This sounds like a pain but having both functions available can be a big plus.
2helpful
How do i get the answer of a simple arithmetic in decimals?
There is a button there that says "S<=>D". Compute it first and when the result is in fraction, press this and it will be in decimals. This button is just above the DEL button.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
