I keep getting the message "Bluetooth linke is busy". What does that mean?
When you get a message like that on any cellular device, smartphone or iPhone...its because your bluetooth device is experiencing errors internally, or either your bluetooth device is connected presently with another device and keep in mind that bluetooth can only connect to one device at a time; meaning that if your bluetooth device is connected presently to any other device, that connection should be terminated in order for bluetooth to be able to search and connect to a new device!
Before you take any of these steps make sure that you have your Bluetooth settings in your phone are set secure; make sure that if any device is trying to connect, would get your attention ( any connection attempted will be prompted on your phones screen) by doing so you will not have outsiders connection to your phone without your permission!
Solution = Turn off your cellular device, and turn it on again! If you're able to remove the battery and placing it again please do so but however some devices like iphones, batteries can not be accessed! ( with such devices, using the Power On/Off botton is good enough to reset the device ).
Power off your Bluetooth headset! ( Do not turn on your device yet)
make sure your bluetooth settings in your phone is not set to automatically connect to any other bluetooth enabled device!
after your phones reset, turn on the headset using the middle botton wich is the round botton, and hold until you get a solid light and make sure BLUETOOTH IS ENABLED AND DISCOVARABLE!
if that doesn't work, hollar at me!
