Question about Maytag Washing Machines
Does a maytag bravos washing machine have to be recalibrated after a new electronic control board was installed?
The machine would skip cycles, so we changed the electronic control board.
    Champion:
  • Maytag Expert
  • 220 Answers
Most do instructions should have come with new control
Posted on Feb 20, 2015
Testimonial: "The new control did not come with one. Do you happen to know what to do?"
  • Dyron Webb
    Dyron Webb Feb 23, 2015
    No model number going to assume your unit has an LED display letss go into diagnostic pick any button besides power, start, pause/cancel hold for 3 seconds release for 3 seconds repeat till 88 shows if there are any stored codes it will appear next i did a service call about a month customer stated skipping the rinse cycle found the hot and cold hoses reversed
  • Jackie
    Jackie Feb 24, 2015
    its a maytag bravos MVWB300WQ0, there are no other buttons to press except for the ones you printed. theres the modifier buttons, end signal off and on buttons, extra rinse button and fabric softener button. So which button do I press and after the 88 code shows, then what do I do?
SOURCE:
My washer continues new cycles if I'm not home to lift lid and remove clothes when there done.
timers control on the board faulty normally technicians replace entire board.
press the helpful button
Feb 06, 2016 | Maytag Bravos 3.8 Cu. Ft. Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
What causes a maytag neptune to skip wash cycle?
Does it work in Wash Cycle on a different selection? Sounds like your Board has an Issue and needs to be replaced.
Jul 20, 2014 | Maytag Washing Machines
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Maytag is clicking when its going to weigh clothes and spin at the end of cycle
It's a faulty relay on the control board. If you remove the top panel and remove the boards you will find a spot burned out on one of the relays. If you know how to solder then you might be able to repair it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Mar 04, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
HC error code....have not touched the hoses since it was installed...?
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer for 2-5 min.
Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa
Aug 05, 2011 | Maytag Bravos MVWB700V Top Load Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
Washing Machines Logo
54 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
