Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print
correctly may be damaged. See "Resolve problems printing a specific PDF
file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's
specific to the Acrobat product. However, the way Acrobat interacts
with the system may affect printing performance. Go to step 3 to
eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it
isn't specific to Acrobat or PDF files. The problem could be low system
resources, insufficient memory on your printer, or a poor connection
between your computer and the printer. Go to step 3 to eliminate some
likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print
from may be unable to connect to the printer or the network correctly.
Contact your network administrator or consult your network
documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
from may be unable to connect to the original printer because of a
communication, hardware, or memory problem. Make sure that the printer
is turned on and connected properly, and then run a self-test on it to
make sure that it's working correctly. For instructions, see the
documentation that came with the printer. You may want to contact your
network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==
http://kb2.adobe.com/cps/316/316508.htmlFor more free tehnjical support you can visit-----
http://tinyurl.com/lkrpwy
It will print PDF files from a scan, ( but not that clearly). Device Configuration is very clearly printed. But if I save the appleworks file as a PDF file, it still will not print. We had no problem printing with our old Brother Laser. It is as if there is a configuration problem with the HP. Is therre something in the driver that needs to be changed?
