I used to work in the AV support department for a large university where we maintained about a hundred projectors in-house. Here is how we approached your kind of problem:
Good luck! Please let me know if this was helpful in fixing the problem, or knowing when to send our for repair, or saving money. Thanks!
SOURCE: Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
SOURCE: someone told me to check my filter before i change
there is no filter on this model. just open it up and blow the dust out of it. if the lamp still won't light, check to see if the colorwheel is spinning. if it doesn't spin, the lamp won't light. if the lamp side screen is clogged with dust, the lamp is shot.
SOURCE: sony svga vpl-es2 won't work
Its because for the foot there is switch who give signal to micro processor or system control.Fix it that.Your problem will solve.
SOURCE: I have a problem with
The lamp cover has a safety interlock device so the unit will not come on if the cover is missing, maybe the safety interlock is faulty or the part of the cover that engages the safety has come away. Other than that I'm not sure what the poblem would be. That is were I would start.
Good luck
