if you go to manufactures website you should be able search type in model no. download for future reference or view manual most of the time they are in usaully in pdf format
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Just disconnect the phone from the mains for a minute and then reconnect. The old message on your answerphone is erased and replaced by the default setting message but you can record over that by pressing and holding the greeting button.
Hi - took me ages to work out without the manual, but when you're in the answerphone menu (described above), press 9 (record OGM) then either 1 or 2 (1 for OGM 1 and 2 for OGM2), speak your message, then press 5 (stop), the message will automatically replay, then you're sorted
