Motorola Mobility ATRIX HD MB886 Android Smartphone Black Logo
M
Maurice Posted on Feb 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I edit contacts
Need to change the name on a contact
  • Official Brand Answer 1,623 Answers
  • Posted on Feb 19, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350707
Points
5677
If it is a Google Contact you can go into https://www.google.com/contacts/#contacts edit the contact and then it will sync to your phone. If you prefer to edit on the phone then you can go to Apps > People > People Tab > Find contact > Select Contact > Menu (3 vertical boxes) > Edit > Update Name > Save
Mark
Motorola Support
How do you correct a contact number?
  1. Open your device's Contacts app .
  2. Tap the contact you want to edit.
  3. Tap Edit . If asked, choose the account.
  4. Enter the contact's name, email, and phone number. ...
  5. To change the photo for a contact, tap the photo, then choose an option.
  6. Tap Save.
Nov 19, 2017 • Cell Phones
How do I enter and retrieve my contacts information ?
When you click n contacts a list of all contacts should display and you can scroll down til you see the name of the person you need. If you need to change any info select edit and change.
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
2helpful
How to delet a person from gmail
Open your Contacts list Click Gmail at the top-left corner of your Gmail page, then choose Contacts. If you are a Google Apps user, click Mail and then Contacts.
Contacts are also available at www.google.com/contacts.
Edit contact information
  1. Find and click the name of the contact in the Contacts list.
  2. Make any changes you'd like to make.
  3. Exit the editing field to save automatically or click Save now in the upper right hand corner.
Add contact to contact groups
  1. Select the contact in the Contacts list.
  2. Click the Groups button .
  3. Select the group you'd like to add the contact to, or select Create new to create a new group.
Remove contact from contact groups
  3. Select the group you'd like to remove the contact from (boxes will be checked next to the groups that contact is already in).
Delete contact
  2. Click More, then click Delete contact.
To remove a Google+ contact, open Google+ and remove the person from all circles. Learn more about circles on Google+.
If you change your mind or mistakenly delete a contact, you'll be able to recover deleted contacts for 30 days. But 30 days after you delete a contact, it will be removed permanently.
Note: These instructions work only with the standard view of Gmail. If they don't match what you see in your Contact Manager, we suggest that you upgrade to a supported browser or go to the standard view by clicking standard at the bottom of your Gmail page.
reference: https://support.google.com/mail/answer/14001?hl=en
Google com
Try these steps:
  • log into your gmail account
  • click on the icon (or your profile photo) in the opper RH corner and click on the "account" link
  • Under the "personal info" tab, click on "edit profile"
  • Click on the "edit" link under contact info to change phone number
  • As you scroll down, you'll see a box that says "details from Google Contacts". Click on the "edit" link to edit your name
Hope that helps!
My iphone has my last name wrong on caller ID
Your iPhone uses the name that is listed in your address book for called ID. On your iPhone, go to Contacts, click on the name of the contact you wish to edit, hit Edit in the upper right-hand corner, and then change the last name accordingly. Once you are done, hit Done on the upper right-hand corner again, and now the correct name will show on caller ID.
How to change a name in contact list
Select the contact
Click on options
Select edit and change the name and number
Thank you for choosing Fixya
My name card edit problems
The device needs a hard-reset to refresh reset expectations back to factory defaults, so make sure you have all your data backed up (contacts, music, pictures, video, etc).
You will then need to manually program the phone, which you can receive all this information through Sprint Technical Support.
Explain to technical support that your "phone info" displays your old # and is not recognizing your new #. This process can be very easy to fix. Call this number 1-877-345-7895. Hope this helps.
I deleted a contact from my address book, but their name and phone number still appears in my recent text messaging contact list when I send a new text message. Can you please tell me how to delete their...
It will probably stay until a different contact takes it's place. You can also try adding their name again exactly as it was. After that, edit from your list of contacts by changing the contact name and number to that of directory assistance or other contact.
Dec 22, 2008 • Cell Phones
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
