A
Anonymous Posted on Feb 19, 2015
5220 quit. says "turn off and on"-no fix. Says "see manual"-no info. Shows "6A81 on top of screen. Error Code?
Quit in mid-print. Tried Off-On several times,no result. Manual contained no reference to this problem at all. Had computer difficulties (file corruption) almost simultaneously but after fixing, printer remains down. Printer is connected thru WiFi. WiFi link works fine for other uses such a internet connections. As of this moment, the number 6A81 appears in a bar at the top of the printer screen. An error code, maybe?
Charles Sedoris
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Feb 19, 2015
Charles Sedoris
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
24916
Points
106
6A81 means the carriage is blocked by something. Start by checking the following image to verify there are no paper jams.
http://ww2.justanswer.com/uploads/wa94sound/2012-04-25_230949_sdf.png
Reply back and let us know what you find.
2answers
Print error 6A81 how can i find out wot to do
You did not say what type of printer it is, or if you have checked for a piece of paper stuck somewhere in the printer.
Example of possible solution:
https://www.inkredible.co.uk/canon-error-code-6a81-fixed
Quoting from web page shown, photo not included in quote:
"Canon Error Code 6A81 - Fixed! We recently came across error code 6A81 on our Canon Pixma MG5250 Printer (using PGI-525/CLI-526 range cartridges). The error could also occur on other printers in this range.
The error code is basically caused by an obstruction within the printer, usually a paper jam but could be any foreign body that has found its way into the printer (those with young children will understand!). The obstruction stops the carriage and print head from moving into the correct position when powering up the printer. The print head should come to rest at the right hand side of the carriage and position itself over the waste ink sponges. If the print head is unable to do so, it returns the '6A81' error message.
You can see from the picture, the position of the two waste ink sponges towards the right hand side. The sponges are spring loaded and move backwards and forwards when the printer initialisation occurs upon start up.
The problem in our case was caused by two pieces of torn paper. One at the far right of the printer which was simple to remove, but the other was stuck in a small opening behind the spring mechanism for the waste ink sponges. This was preventing the sponges from being moved freely and seated correctly, which in turn meant that the print head was unable to pass over them and come to rest in the correct position.
To remove the torn paper we turned off the power to the printer (to prevent any damage to the carriage mechanism) and used a pair of tweezers to carefully pull the offending article through the small gap. We missed this hidden piece of paper the first time we checked for obstructions so it's worth shining a torch in and having a good nose around!
Close your printer lid, power on the printer and et voila... Canon error code 6A81 is no more!"
Error 6a81
Turn off power, remove power cord and wait 10 minutes, then reconnect power cord and turn unit on, if this does not work then advised to contact canon service centre
My touchscreen quit working
You must recalibrate the screen,read your device's manual for how to info.
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
k24674
ADMIN Andrew
ADMIN Andrew
