SOURCE: having problems with fan assisted oven on leisure
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
SOURCE: Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
SOURCE: Would like to locate a
unfortunately,
the user manual for your Leisure Roma 50 Electric Cooker is not available anywhere online.
The manufacturers of this product did not make it available. I went
further searching and couldn't find any.
I would suggest you
contact the manufacturer of your Leisure Roma 50 Electric Cooker via phone or e-mail and
request for the manual from them. They might give it to you or direct
you to a dealer where you can get the user manual.
This is the best you can do to get the manual you are requesting for.
Good luck.
SOURCE: Timer leisure Roma 100
You will have to resort to your owner's manual. Every Range is different. If you don't have the owner's manual, check with the manufacturer online.
