SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
SOURCE: Instruction Manual for Hotpoint washer dryer wd420
Try this link:
http://www.hotpointservice.co.uk/hs/pages/manual/manual/search.do
Enter the model number in the search box, and download instructions.
Please rate my solution.
Thankyou.
SOURCE: What's wrong with my washing machine (Aquarius
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
SOURCE: Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
SOURCE: washing covered in dirty marks
It sounds as if a bearing seal was defective when it left the factory and is allowing lubricant to bleed out; I would consider this a warranty item and if the company doesn't care to make it right, file a complaint with the local BBB relating to the dealer where you bought it and nationally against the company itself.
Maybe they don't want this stain on their reputation but this is another reason to avoid US manufacturers.
Testimonial: "Thankyou for your helpful comments."
